HD9 brakes |
Intl1466
Topic: HD9 brakesPosted: 28 Jan 2023 at 5:19pm |
Looking for HD9 brake bands and hardware. Any info would be helpful. Thanks
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 28 Jan 2023 at 9:44pm |
If you need new brake linings, steering clutch .com has them. I don't see a complete band set. They do have complete assy for HD6
Semper Fi USMC 1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4867 |
Posted: 29 Jan 2023 at 8:32pm |
Getting the band out of the tractor is the big job. Get the old fashioned hollow rivets. McMaster-Carr I believe has the rivets as well as rivet set tool, you just wrack it with a hammer. Or a a real old brake repair business may have tool hid in the back of the back room.
I had access to one you stepped on a pedal and if smashed the rivet perfect every time. It was made of mostly cast iron was not bolted down, and feel and broke in the big earthquake we had here in 03.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 30 Jan 2023 at 7:11am |
if your bands arnt trashed, Rick Corder in Missouri does excellent work. He has done several projects for me
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 31 Jan 2023 at 7:29am |
As Cal mentioned, I can help on the relining of the band brakes...just need the length of the material, the width and the thickness, which can usually be determined by checking the thickness at the end of the brake band, since it's usually still closer to the original thickness...thanks, Rick
Intl1466
Posted: 03 Feb 2023 at 8:39pm |
Brake bands are completely shot. Had water laying inside case for a few years. Clutch was seized up, but I got that freed up and working properly. Probably gonna take the complete brake band assy. I check with salvage yards for used, most people never heard of em.
Intl1466
Posted: 03 Feb 2023 at 8:42pm |
I would like to find a pdf operator manual for filter part numbers and oil specs
gemdozer
Posted: 04 Feb 2023 at 10:02am |
If you not hurry I should have 2 used brake band assambly but my shop is closed until april
Intl1466
Posted: 12 Feb 2023 at 3:50pm |
Not in a hurry. I’m running without right brake for now. Lemme know when you get them
Rick
Posted: 12 Feb 2023 at 8:11pm |
Jonathan...Good evening...I take it that you're letting ME know that you have the bands headed this way to me? You didn't specify whom you were telling that to...LOL Thanks, Rick
