HD7GB
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2018 at 6:28pm
Thumbs UpMore pictures?
Cannoncollector View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 7:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 7:24am
Anybody that has one of these better keep those hydraulic tubes clean where they run into the battery compartment area or saddle tank the other sides of the lines that are exposed in the open are clean as a whistle I bought some tubing pre bent on an angle and my Pro welder is splicing in new corners as we speak
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 7:27am
All the rust was air hammered and knocked off and being painted.
The shifter Tower is being rebuilt with some new pins and bushings they had a pretty high quality set up from the factory even some needle roller bearings and seals on shafts and Bell cranks very high tech, I've replaced with new oil impregnated bronze bushings and adding grease zerks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 7:30am
Now specked out some brand new aftermarket Ripper Shanks that fit cat 953 are going to fit quite nicely stay tuned for the video of this thing running like a raped ape and the Ripper shanks ripping and the four and one bucket claming and dirt flying, surely to turn any man green with envy lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 9:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 2:34pm
Update I had the lines repaired and I installed them. You can see the welds where new elbows were installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 2:35pm
Does anybody have ideas how to keep mice out of those perfect areas for nesting?.. I was thinking about filling in the areas with that insulation in a can that expands or slopping lots of nasty grease in there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 2:38pm
And then I celebrated by taking the hd4 for a spin 😥😂
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 2:58pm
Well placed often replaced moth balls
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 3:00pm
Segments look pretty solid, rails look pretty well used up as well the shoes on them. Be wary when turning if much slack in them as the old snaky rails like to roll off.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 3:34pm
I saw some spray on foam at the local hardware store.  It had Jalipeno flavor it it which is supposed to repel mice and insects, unless, of course they are from Mexico...
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 5:26pm
DMilller yes the rails are lean and the pads are too but the sprockets are new as well as the pins and bushings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 5:27pm
And I didn't know till now they did flavored expanding insulation in a can to deter chewing pests good information
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 2:39pm
Nice find. Birds nested in my cat 943 one time. snakes were on it after the bird eggs. Used it on a job and they were sticking their head out all over trying to get out. some got out through hole in belly pan while running it.
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 5:35pm
I like the HD4  thats a great photo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 6:07am
Update.. well I'm making some progress, unfortunately my engine oil pressure is low probably due to previous owner running it with fuel diluted engine oil, due to leaky injection pump seals., and I have a smoky cylinder and slight burnt valve.
But upon testing out the transmission, I noticed that my low gear is not all that low after all, too fast and even though I can get a full bucket of compacted millings digging in, it really does not want to easily spin the tracks..
Do I have a weak trans?, is my question
david weldon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 8:27am
Hello I would love to see a video of it working thanks David.
This page was generated in 0.180 seconds.
