HD7GB loader rear engine seal #
Braswell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Braswell Quote  Post ReplyReply Direct Link To This Post Topic: HD7GB loader rear engine seal #
    Posted: 11 hours 7 minutes ago at 8:48am
I have the wet bellhousing and I need seals for the crankshaft . There are 2 separate seals … one facing the engine and the other facing the bellhousing. They are identical National # 77286HC I’ve tried a few places to match them up but I need the Original Allis Chalmers part number for them. All I can find is the seal for a dry bellhousing housing.
Reliance sent a seal they say is a double lip but it sure doesn’t look like one . Any help appreciated or where to find the parts manual
Randy
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 15 minutes ago at 10:40am
What is the serial number of the tractor and engine? Four, or six cylinder?
That's All Folks!
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 10 minutes ago at 12:45pm
74029500 seal from Minnpar is about $50. Pretty sure the 670 had same rear seal as 685/11000 series.
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 51 minutes ago at 3:04pm
Yes...I concur with Trevor....that part number should be 74029500...available from Minparr.  should be applicable to tractor serial numbers 27201-27950 and 34U27951-up. My parts books do not show any configuration of 2 seals....have no idea of what you might have going on there?  Yes that seal is the same for both the 3500 and 11000 engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 60 minutes ago at 3:55pm
Problem with a Gb is they use a IVECO Engine.  Totally Different Animal.
