HD7G loses lube pressure after 15 mins
turboturtles View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turboturtles Quote  Post ReplyReply Direct Link To This Post Topic: HD7G loses lube pressure after 15 mins
    Posted: 03 Apr 2020 at 7:49am
I've got an HD7G that loses transmission lube pressure after running for about 15 mins.
I can kill the engine for approx 1 minute, and it will run for another 15.
It was worse, and would run 5 sit 5 before I went through all three screens and 3 trans filters, oil change.  Haven't noticed anything large in any of the screens and filter (bearing material ect)
Been in contact with "Dmiller" on here, and hes helped me locate alot of hard to reach and see places.  Super helpful.
Using AW32 oil in place of the 10W.
No visible leaks.
I'm a chemical operator by trade, all my intuition tells me the fluid is getting kind of vapor locked, because as soon as I kill the engine....it all runs back to the sump in short order and runs fine.  Not a warm up /viscosity problem.  Feels more like a floating restriction, or a check valve somewhere is stuck open or closed.
I searched the forum and a guy named DoctorCorey had an identical issue, but never replied on the thread about how he resolved it, I did see he sold his HD7G "ready to work" but he hasnt been active here for a couple years.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2020 at 9:38am
You could try ATF oil or 10 standar oil no detergent
This page was generated in 0.171 seconds.
