HD7G engines
superchief View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote superchief Quote  Post ReplyReply Direct Link To This Post Topic: HD7G engines
    Posted: 19 Apr 2011 at 6:45pm
My Allis Chalmers book states the only difference between the 6000 & 7000 engines is the turbo chargers. However I cannot confirm whether or not there is mountin holes for the oil pump for the 6000 wet cluth if I were to install a 7000 engine. Can anyone confirm whether the 7000 has the necessary mount area for the wet clutch oil pump?
thanks, Superchief
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 6:03am
The 6000 and 7000 is the same motor and just the turbo is the difference
HD6 Merv View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 10:25pm
Chief. Gemdozer is correct 6000 and 7000 basically the same.
HD7G will have the drive for the 2 steering clutch pumps, this is same place as the flywheel clutch pump.
On a HD6E it has the 3 pumps on together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote superchief Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 10:19am
Hi Merv.  Thanks for the information. Have just purchased a 7000 series motor on gov. auction, and I think everthing will work out ok as long as the engine we purchased  is good. Have a good day, Superchief
