Hd7 information please
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Topic: Hd7 information please
    Posted: 29 Jan 2021 at 12:28pm
   Looking at a HD7 dozer.  How hard is it to change the main clutch and also the steering clutches if needed?   They also say the hyd is "a little slow"   Any ideas.   Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 2:12pm
on those style monolithic powertrain, it requires pulling engine to replace clutch.  if you cant stand on your head and do it through the hole in the floor, the engine has to come out.   no experience on steering clutch on a 7 but if if its like a 10, you have to pull the pinion out and move some things around to remove steering clutch.   slow hydraulic is probably worn pump but could be too light viscosity of oil.
Edited by CAL(KS) - 29 Jan 2021 at 2:14pm
