HD6G
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Topic: HD6G
    Posted: 15 Oct 2022 at 8:12am
My HD6G has not run in several years After adding oil to the motor, transmission and final drives It started and ran well. I was surprised when a large mouse nest blew out the exhaust pipe. The exhaust pipe has a weather protector and was covered with a bucket and was under a tarp. The exhaust does not have any holes in it. Darn clever these mice. Usually mice like the steering clutches.
I'm looking for the front driveshaft yoke for my HD6G and rings for my Detroit 2-71
I have a reground crankshaft and bearings for the 344 HD6 motor
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 9:03am
The front yoke are 2 model  ==ubolt==bolt on joint
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 3:40pm
Early HD5 usea Vickers hydraulic pump , it was superceided by the Hydreco pump - both uses a mount for their own pump system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2022 at 8:53am
Hector
my hd6g is a 1956
The transmission yoke is #085879
The yoke is sloppy so the transmission seal leaks oil
I'm looking for a transmission yoke that is in better condition than the
one I have
George
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2022 at 10:57am
is it the yoke or the seal assembly?
my 6g is a 56 and still has the old style seal, not a lip seal.  you can buy that seal asembly new from general gear
Edited by CAL(KS) - 18 Oct 2022 at 10:57am
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2022 at 11:43am
I was advised to change that bearing when you do the seal. If it goes it drops the balls into the gears below it. Generally spitting the transmission case open, or at least breaking teeth off the gears. I forget details but was not frustrating job, since it is not Oh why did I get into this memory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2022 at 2:32pm
I have a rear yoke but have no number on and I check it on my input shaft and seal ring and it fit oké and dimention 3 1/2 inch hight and screws holes are 3 1/2 center by 1 1/2 inch
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 8:34pm
  You were able to pull this bearing from outside the case?
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2022 at 7:44am
yeah comes right out the front of case iirc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2022 at 11:37am
As I said no bad memories so it had to be easy. And it was not many years latter the lower bearings failed.
In a farming situation I was pulling ( a sprayer I think) and started up a hill, stopped to shift. Things came loose ( assume a ball from a bearing) and the gears locked up. With the clutch disengaged it rolled back to the bottom ( brake locks are iffy always put in low and shut off if I get off on a hill). Towed it a mile to home to work on. All the loose pieces settled in the bottom and harm to gears.
Edited by Ray54 - 20 Oct 2022 at 11:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2022 at 1:13pm
Neverr had a problem with the front bearing but replaced 2 of the rear bearings which a double row ball bearings , cage for balls broke and they all moved together which set the pinion in wrong place to ring gear .
 I did rebuild the transmission a couple times over the last 40 years I have had my HD5G, and replaced all the bearings as well as welded one tooth back on high speed reverse gear. That has held up over last 25 years but seldom use the high spped side .
  Rebuilding all the parts in the shifter from cross shaft to the ball end of shift lever made the biggest change in operation as now it finds gears easily and shifts positive
This page was generated in 0.057 seconds.
