HD6G
Message Reverse Sort Order
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Topic: HD6G
    Posted: 08 Jan 2019 at 12:21pm
usual problem is the lip type seal on the drive shaft gear on the fuel transfer pump on side of the main fuel injection pump.
Is a lip type seal part #4231  avaiable from SKF or any other bearing/seal supplier.
IF you still have a problem after fixing transfer pump the problem is  3, O rings in the hydraulic head.
tits tyres and tracks
they all cost you money
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 8:38am
If it was a 180 or 190 it would be the seals on the diesel pump
on the shaft going into where the timing gears are that drive the
pump.
   John Carlson
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 6:26am
Hello Loaders
What seals would fail to cause diesel to get into oil?
thanks for the help
HD3
