Hd6g
Lewischaz1092 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g
    Posted: 16 Jul 2017 at 9:08pm
Was curious to if anyone can tell me the year off my crawler and if anyone has a diagram for the engine belt routing it's a hd6g tractoshovel serial 298 or 290 depending if you look at the one in the rear housing or on the loader arm
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 7:26am
The number on the final drive housing "HD6G 290" is a 1955
If it has the original HD344 motor with crankshaft driven belts, the rear belt is powered by the upper 3v pulley and drives the water pump and generator. The front (2) belts are driven by the crankshaft and drive the upper pulley. The later motors are different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 8:23am
It has a the original motor what I was looking at on the routing is once I go around the generator and water pump back up to the fan it rubs the tensioner also is there a way to get the other two off without taking apart the nose
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 12:30pm
Also 290 is the one on the arm 298 is the housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 3:21pm
The radiator shell tips forward pivoting on the forward pins with the square hole. Remove the bumper and rear hard nose bolts, pry and wedge the area outward before tipping. There is a locking mechanism that is relieved by this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 3:51pm
Ok thanks I'll give it a shot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 9:39pm
Ok got the belts on running like a champ now any body know where I can find grouser pads reasonable
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 11:00pm
Do like I did on my HD5 - Pads were straight but worn - so i welded rebar onto them using 7024 drag rod - I put 2 bars on each pad - leaving the center bar stock .
 Has held up well over the years - spend a few days out in shop welding them on and many pounds of rod .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 6:13am
Where did you find "V" belts? I was unable to locate the correct length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 12:02pm
I plan to weld some rebar on for now actually but would like to put new ones on in the next couple years cause the rest of the pads are worn too not just the bat, and as far as the belts I jusst used string line to measure the length and called O'Reilly the generator belt was a b49 for mine don't know on the other 2 didn't have to replace them but get them off to replace the one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 12:04pm
Also on the belts Napa is usually good for equipment they may have to order it but can usually get them in a couple days that's where I have to get the belt for my sickle mower
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 4:59pm
If it is the same setup for the two on fan drive as on a 516 then C 60 fits our AC 45 grader.  That has C section for the waterpump and generator though and I'm running an alternator not a generator.
Edited by Ian Beale - 18 Jul 2017 at 5:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 8:55pm
Correction go with the b48 49 was a tad long but works, also anybody got any ideas why the hydraulics would be surging and the vavle getting hot? And yes they are at the proper fluid level
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 10:36pm
Sounds like something is not relieving.
 Or a third valve stuck in a load position or some thing like that...
 or maybe plumbed in wrong...
   Just how hot is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 5:04am
Did this loader once have a hoe, on the back?  If so, it may have a selector valve button, on the valve bank. push (or pull) the selector, and you went from driving the hoe to loader, and vice versa.  if the knob is lulled (or pushed) slightly, it can cause the heating/surging problem...
IIRR, the knob was on a separate valve bank, in such a position as to hit your knee, as you get on or off the machine...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 9:42am
It's getting hot enough you don't want to bump it with you arm. The arm vavle for the arm is stays in whatever position you put it in not just neutral and float. To the best of my knowledge it never had a hoe unit as much as I would like to have one. But I have only had this machine a few days trying to work all the previous bugs out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 9:53am
Is it possible could be clogged up in the suction line fro. The tank to the pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2017 at 8:41pm
Any body have a diagram of the lift cylinders
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 8:25am
You're looking for a hydraulic schematic or a diagram of the actual cylinder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 8:39am
Diagram of the cylinder itself got a seal leaking
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 12:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 12:30pm
The rod seal has (4) chevron seals. Tighten the (4) 3/8-16 cap screws to reduce the leak. If that doesn't stop the leak replace the seals and the rod bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 12:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 12:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 12:33pm
Originally posted by doctorcorey doctorcorey wrote:
Is your leak internal or external?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 12:44pm
Thanks for the pic it's right were number 5 is in the diagram previous owner over torqued it an pushed the seal out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 1:08pm
Do you have a part number for pieces 3/4
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 1:15pm
sorry wrong part list. #3 is 3013389 Oring, cylinder head. #4 is 301338 Ring-Back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lewischaz1092 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 2:21pm
Thanks really appreciate it I'll see if can get them ordered
This page was generated in 0.089 seconds.
