HD6G Weak Hydraulics |
Paul-HD6G Start-up
Joined: 01 Aug 2021 Location: LaPorte, IN Points: 7 |
Topic: HD6G Weak HydraulicsPosted: Yesterday at 7:12pm |
I have an HD6G that I'm working harder than its had to work for the last 20 or more years clearing fence rows. We've had this machine for about the last 50 years so I do have a little history with it. The machine sat idle for about 15 years up until about 4 years ago. But I was able to get it started after new batteries and refreshing the fuel. Over the last 4 years I've used it for some small short term projects with no noticeable issues. However, I started using it to push over some trees while clearing an old fence tree line. The longer I use it the weaker the hydraulics become. Can anyone point me in the right direction? I have not been able to locate a new hydraulic filter. I don't have a book on the loader part of the machine so any information would definitely be helpful. Recommended fluid? Filter part number? Any other suggestions..... Thanks for the help
Codger
Posted: 17 hours 1 minutes ago at 6:25am |
There are a couple of things that come to mind that are very basic in nature. First is fluid parts wear that exacerbates as the fluid/hydraulics warm. Usually you can discern this by the engine needing higher revolutions to accomplish the same repetitive tasks as the system warms. The second is pressure relieving at too low of pressure. One would normally see this hot, or cold. You would need to tap into the system and check/adjust system relief pressure as a starting point. If you cannot surmount system relief pressure by adjustment(s), most likely the main hydraulic pump needs rebuilt, or replaced.
That's All Folks!
Paul-HD6G Start-up
Posted: 3 hours 4 minutes ago at 8:22pm |
Thanks for the input
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54859 |
Posted: 2 hours 40 minutes ago at 8:46pm |
Might also be suction leak or plugged strainer, if so equipped...
