hd6g tips or tricks?
wildbill26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Topic: hd6g tips or tricks?
    Posted: 12 Apr 2014 at 5:51am
I have a friend who.owns a hd6g, he has never run heavy equipment I have run mostly cat 955, any tips or tricks to know about operating one? I will be using it to haul wood, in the bucket and cut in a driveway also, thanks
1950 wd wide front w loader
1940 b, 1939 m crawler
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 12:11pm
DON'T use main clutch as a slipping clutch - in or out , use steering clutches for control.
Set throttle for speed and leave it - unless it has decelerator.
Hope it has counterweight - carry load low when traveling - any machine !
Don't try to move a mountain with the bucket , start cut and fill bucket while moving , shave the material - not brute force into it.
 Will push more than it will carry.
Edited by Coke-in-MN - 12 Apr 2014 at 12:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 1:28pm
Thank you coke, unfortunately it dosnt have a counter weight, the decelirator is that the pedal between the brakes ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 7:23pm
Unsure on that machine - center pedal is normally for applying both brakes at same time as well as engaging steering clutches to stop all power to track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2014 at 6:28am
Thank you coke, I had thought it was a brake, I ordered an operators manual since he didn't get one, and he cant run it, ill make sure to post.some pics when I get started
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 9:28am
center pedal on all I have used is decelerator pedal. Take it slow, they are not a high speed machine, do like coke says.   He will be a very busy guy with all the hand controls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 3:55pm
Dang might have to try a HD6 some day - My HD5G and my F/A FD5  are different machines in many ways but once you run any machine it becomes easy .
 Well except for when I had the HD4 - it seemed I got my feet and hands crossed up all the time .
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2014 at 10:14am
my hd6g has a decal pedal in the middle they were used on the new style hd6gs with the 6000 engine my dad call them high seaters now the couple of low seat had6g we had with the buda engines didn't have the pedal just the throttle just like the hd5g
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2014 at 6:25pm
thank you all for the replies
This page was generated in 1.500 seconds.
