HD-6G Questions |
Page 12> |
| Author | |||||||||||||||||||||||
orangeman
Topic: HD-6G QuestionsPosted: 25 Nov 2010 at 3:40am |
Hey Guys: A wonderful thanksgiving to you.
Found an HD 6G near me, Buda engine is seized and the cross shafts are worn in the front idlers.
My limited research shows that the D344 Buda block was a sleeved engine and kits are available. Have any of you rebuilt the D344 block and any particular weak areas to look for.
Also, do you know if the idler cross shafts are available as a kit, or do I need to get with my friendly machinist to have made up?
The machine is whole and complete, is close and the price is very reasonable, less than scrap value.
Appreciate any advice that you can offer. I'll bet Coke and some others have some good insight. Thanks much...Orangeman
| Sponsored Links | |||||||||||||||||||||||
gemdozer
Posted: 25 Nov 2010 at 6:49am |
If I can help am still have some used HD6 G parts
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 25 Nov 2010 at 6:57am |
from my knowledge, early budas were trouble and the later ones were ok, then the allis chalmers were even better. you could probably retro a 2-71 or even 3-71 in her if you don't mind it not being exactly original, i think the detroits are a better engine and certinly more popular. as far as the shafts, find used and rebuild but check the rest of the undercarriage first to see how bad it is and if the tracks were just overtightened or the pins and bushings are shot. alot of hd5 parts are the same so keep your eyes out for a doner machine.
orangeman
Posted: 25 Nov 2010 at 2:26pm |
Hector thanks for the parts post appreciate that, if I buy the machine I may drive up to visit .
To dads: I would prefer to stay with the Buda if possible. Can you be a bit more specific about the troubles with the early buda's. I see quite a few early buda's on you tube and they seem to be doing OK.
I checked the machine out this morning and I suspect that the inside of the idler is shot as well as the shaft itself. Bottom rolls, pins and bushing appear to be in very good shape.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 25 Nov 2010 at 3:43pm |
Track on 5 and 6 as well as rest of undercarrage and finals are all the same (except extra roller and track length). The front idelers used timken bearings instead of bushings and they were known bend when overloaded.
Early engines did have some problems and later updates were made within the years of mfg. as other changes and updates in full machine were incorperated.
orangeman
Posted: 26 Nov 2010 at 3:30am |
Hello Coke: When you reference the early machines do you mean just the first year of production? Was or is there a good bearing solution for the timken bearing issue and assuming the commonality between the 5 and 6 machines, were the idler bearings upsized for a shovel machinesdue to the additional weight in the bucket as compared to say a machine that is equipped with a dozer blade?Thanks for the info noted above. Appreciate it... orangeman!
orangeman
Posted: 26 Nov 2010 at 4:09am |
Jeepers wish I could think clear, had one other question, I see in my Allis library that AC released the HD6 to the military but have never seen a picture of one. Does anyone have a pic of the military HD6?
Coke-in-MN
Posted: 26 Nov 2010 at 8:42am |
Same on HD5 and HD6 on both loaders and blade machines to my knowledge.
Each year there were little things that changed, so from firstto last many small updates to the end when machine looked different.
dadsdozerhd5b
Posted: 26 Nov 2010 at 12:16pm |
if memory serves the bottom end was an issue not being able to hold the load. as with any machine, you have your good one and bad ones, i don't think they kept the budas for too many years before they switched to their own engine. do you know what is wrong with that one? unless the inside of the roller is totally hailed out, you may just be able to rebuild it. they were greased and some did not have a place to put grease in so you ran it until it gave out.
orangeman
Posted: 26 Nov 2010 at 3:23pm |
Hey Dadsdozer: Yep the son of the original owner let water get in the block over the past 2 years and number 4 cylinder filled up, engine seized. He's a good mechanic, but time and elements bested him this time.
There is approximately, 1/4 - 1/2" deflection between the end cap and the hub of the idler assembly. So my guess is that the ID of the hub is wallowed out, the bearings are shot and the cross shaft is worn. Been around this issue a time or two with the little early Cletrac HG's.
I have several Allis H-3's and none of them, either dozer or loader show this amount of wear in the front idler hub. What is suprising is that the chain, plates, pins and bushings, sprocket and top and bottom rolls are in real nice shape.
From talking to the son he stated that the loader was exceptionally strong. So my guess is that the bucket was overloaded many times. With the cantelever effect of the dead load in the bucket needing to be displaced, the cross shafts that carry the idler must take up the load. I am beginning to think without benefit of looking at other HD6- G's that the cross shaft was perhaps undersized for the load that could be taken up in the bucket. Since the bucket is 1.5 yds. according to my engineering references, that would equate to 5,000 pnds full load. A heaped load would be even more weight.
For practicality sake, I am in an evaluation and costing mode, but at this point given the engine work needed and the defective front idlers I am beginning to lean toward a Caterpillar 955 or other 900 series machine. Many of the sage old time Cat skinners have advised me to invest in a Caterpillar if I want reliability, but my heart is and has been with Allis's up to this point. So all options are open at this point.
While my thinker is stil working, could one overbore the hub and machine a new larger cross shaft and install bronze bushings and a nice grease fitting to make this ole girl come to life again? I have less concern with the engine issue than I do the defective idlers at this point. Would appreciate anyone thoughts, tips or suggestions at this point. In close, I am checking my sources for a new old stock set of front idlers or good used.
Coke-in-MN
Posted: 26 Nov 2010 at 7:08pm |
The slop can be from just the bearing being bad, cone and cup system and if carrier for rollers went , could be slop, I know mine was real bad but easily rebuilt and resealed with just bearings and seals. Had 3 other wheels but axels were bent , and it is from overload mainly backing up as that transfers all weight to front ideler wheel.
I believe the life of a HD6 is superior to a 955 and is a lot cheaper to operate and to work on.
Unsure of your location , can try Thill Track and Tractor in Eau Clare WI and they may be able to supply or find you parts. I sold a couple front idelers to members on here and do not have any extra now.
orangeman
Posted: 27 Nov 2010 at 3:44am |
Hello Coke: I could see where the backing up with a full load would be an issue. Now for the engine. Since the loader is on the machine it is very difficult to tell if the engine is sound, (i.e. no cracks). If the block is sound I could refurbish the Buda, but I have access to several mercedes benz 123 diesel good running engines that could serve as a power plant and they would be much less cost than a rehab on the Buda.
Dadsdozer commented using a Detroit out of a 5, but there are only a few around here and they are running machines, so was considering optional diesels that could be used at less cost than to rehab the Buda.
If one were to pull the block, is it best to pull the engine with the bellhousing or just the engine? I have pulled the blocks from the H-3's which are simple, but this would be the first HD6-G I have worked on. Have a Great weekend and appreciate the comments. Orangeman!
Coke-in-MN
Posted: 27 Nov 2010 at 5:10am |
The 2-71 is only 48 to 52 HP a 3-71 would get you to 70+ a 4-71 would be in the 110 range.
The engine + clutch is easierto take as unit and work outside frame.
Usure of the engine you mentioned , as bellhousing will be the problem matching as you will need the clutch to be a over-center type to connect to trany drive. Some units I believe used a wet clutch for cooling .
dadsdozerhd5b
Posted: 27 Nov 2010 at 6:00am |
as a side bar, if you do not want the agravation of rebuilding or working on it to get it going, buy it and part it out. if the undercarriage is that good it will bring a good buck as they are no longer available. i have tried several sources just for the pins and bushings and have come up empty handed. once you have gotten the best parts from it, scrap is up and can put a good downpayment on a running machine. i also beleive as coke said that an allis hd5 or 6 will outlast a 955 in the long run and have less repair and maintenance costs. now a 955 is a larger machine and with size comes expense. certinally your call. does your front idler have spokes or solid? i have a few spoked idlers in fair shape i could sell. where are you located? coke is right about the bell housing matchup, as the detroit should bolt right up. personally, i think a 3-71 would fit nicely and be a relatively easy install. 2-71 would be a little underpowered but that is what they put into the hd5 loaders. i beleive the only big difference between the 5 and 6 was the engine. i aqhve a hd5 loader but do n ot have it up and running so i cannot say if it has enough power. coke had a 2-71 looking for a good home. there are several cheap on e-bay now and are easy and inexpensive to rebuild.
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 27 Nov 2010 at 8:18pm |
Here you go.
are genuine." - Mark Twain |
Coke-in-MN
Posted: 27 Nov 2010 at 9:44pm |
6 has 2 more links in track and 1 more roller on frame. Mainframe is longer and front metal changed to adapt to longer engine also 12V to 24V electrical system
orangeman
Posted: 28 Nov 2010 at 3:07am |
GBACBFan and Coke: Thanks for the posting on the Detroit Diesel and the information on the electrical and track length. The HD6-g that I am looking at has the six bottom roller undercarriage and the 2 speed reverse in it. I was looking the grouser plates over and most of them still have the original black patina between the grouser bars, so not a lot of wear. I am wondering if the grouser plates on the HD6 will fit on the H-3? I need to take a few more measurements. Thanks to all of you for the great info. Appreciate it. Orangeman |
acisbest
Posted: 29 Nov 2010 at 4:56pm |
I have an early HD6G, First year, in the 3000 serial numbers. I can see that they made updates to the belt system in later models. My fan/idler mount was worn, had to fabricate special parts to straighten it out. My engine runs good but burns a lot of oil.
There was a guy in Frederick MD in the mid 90's that knew and was buying parts from. He had about 3 HD6G's that he still used for excavating. His biggest problem was the main pinion gear in the rear. He said is was the dozers weakest failure point.
Coke-in-MN
Posted: 29 Nov 2010 at 5:32pm |
Problem I have had is the double-row ball bearing on trany output shaft will go bad and allow the pinion gear to ride up on ring gear. This bearing is shimmed to get proper lash on ring and pinion, or dept into gear. Timken rollers control the left/right position of ring for other tolerances.
gemdozer
Posted: 29 Nov 2010 at 6:33pm |
I ben in parts business and never sold a bevel gear pinion shaft for HD6.
orangeman
Posted: 29 Nov 2010 at 7:29pm |
Me Again: I was going through my AC library and noticed that the Tractomotive Corporation referred to the loader as the TS-6. The form is date stamped June 1956. In that booklet they show a bunch of things that could be adapted to the loader instead of the standard bucket, including a drag bucket, Rock fork, tractodozer moldboard, Angle tractodozer, crane hook, lift fork and trench hoe.
Sure would like to see some action photo's of the HD6 with those various attachments. Thanks guys for sharing your insights, much appreciated. Orangeman
acisbest
Posted: 29 Nov 2010 at 8:01pm |
Thats interesting that you have never sold a pinion gear. The guy I had visited had about 3 of them go on three different dozers. Last time I had visited him he had welded on a swept back rear onto the newer type straight hood version just for the better rear with good pinion. He cut the rear off of the swept back version at the frame and welded it onto the new dozer. Another HD6G had a half a tooth broken off of its pinion but he was still using it.
Maybe he was using them too hard, he was digging out house foundations.
I have the brochure that shows all of the options available on the HD6G. Would love to see the back hoe attacment, but I doubt any survived?
Coke-in-MN
Posted: 29 Nov 2010 at 8:31pm |
Lot of those attachments were listed for the HD5 / TS5 also like a cab and a V plow for snow, aswell as that back hoe (scoop) for the loader tractors. best i have seen wass ripper for the HD6 , guy in Osseo MN had 3 setting in front of his shop and ended up scrapping all 3.
Coke-in-MN
Posted: 14 Dec 2010 at 4:03pm |
mudder45 ( see his profile for e-mail address )
Hi guys, I have a complete AC 1967 HD6G for sale for parts . info can be seen in the forum classifides section page 2. Price is negotiable. you can click on the big and ugly to see a picture @ www.equipfind.com/heavyequipment/1967AllisChalmersHD6G
Saratoga NY area. I wish to sell it as one unit rather than part out. The old picture is from an old add I put out. Price, we'll talk ;-) Rick ( mudder45 ) |
HD6GTOM
Posted: 15 Dec 2010 at 4:12pm |
Orange man I have 1 left. It has a later engine in it. The crank looked to be a larger diameter, the counter bal shaft is heaver duty than the old ones. As I read through some of the posts I read about ring gear and pinion problems. I have never had 1 go bad. I do not remember when they updated to the stronger parts. I think it was a gradual thing as the HD6 evolved. I do have a compete engine for parts. It has a hole in the block. Its in south central Iowa. |
Dale
Posted: 16 Dec 2010 at 9:26pm |
acisbest
I have a mid 50's HD6G track loader with the tractomotive factory installed backhoe attachment. Originally came from the Lima Ohio area. The hoe works real well and I paid for part of it's purchase cost by digging the footings for my shed. It's a 2 stick unit (with 2 outside sticks for the stabilizers). I just this past year had to install new steering clutches after a mouse ate the rubber boot on the brake rod and set up housekeeping in the right clutch well. Mouse pee is stronger than JB Weld. Put in the new ceramic disks from General gear and Machine in Boise (a real good source for parts I found). Kind of a long with the hoe, really heavy, clumsy machine but useful and neat none the less. Starts on about the second crank over. Also have one with a ripper (3 gang but missing the teeth) and one with a winch. These machines are surprisingly strong and were every bit as robust as the same vintage Cat. I'm not sure what the Cat equivalent would be but I also have a D4 Cat but I think my HD6G is a heavier, bigger machine. Maybe someone on here knows what the supposed Cat equivalent was. |
acisbest
Posted: 17 Dec 2010 at 6:13am |
Dale,
Would love to see a picture of your HD6G with the back hoe attached. When I first bought my HD6G the left clutch was frozen. Opened up the clutch well and it was full of ice. Previous owner left the drain plug in. Had to use metal wedges to compress the clutch enough to remove it. Now my right clutch is toast but I have to many other projects to do and I don't use the dozer much so I get by with one clutch. Never thought about a mouse building a nest in there.... When I get time I'm going to open up the covers and see what is doing down there. Maybe even pull out the right clutch. I HATE mice. I rescued an outdoor cat to keep the mouse population down. He does a great job, eats them from head to toe. Would love to have a winch but would only want to pay around $200, so I may never get one. Don't really need it but I do have to pull some large logs out of the woods occasionally. Cat equivalent might be a 999? There is an orchard near me that has two 999's. They look only slightly bigger than an HD6G. The orchard owner died and the 999's are rusting away. When he was alive I saw that he had both of them running. http://williampowell.net/Frames/hd6gframe/hd6gframe.htm |
Coke-in-MN
Posted: 17 Dec 2010 at 7:02am |
Those clutch plates can be found used also as they are the same as HD11 parts. Juyst less of them in clutch pack. I changed my HD5 over long time back . I do have a bunch of the fiber clutches (used) and couple metal discs.
That drain hole in bottom of case is important to keep clean and open to prevent water or whatever from filling the case. Edited by Coke-in-MN - 17 Dec 2010 at 7:04am |
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 17 Dec 2010 at 7:43am |
HD6 for sale in CT.
Chris/CT
Posted: 17 Dec 2010 at 7:44am |
Page 12> |
