HD6G pins & Bushings
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Topic: HD6G pins & Bushings
    Posted: 27 Oct 2011 at 3:53pm
Where can I purchase pins & bushings for my HD6G?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 3:59pm
If your rail height is good you might find them doing a search for local track shop. smaller independant places . Can try Thill track and Tractor , Eau Clare WI, Northern Tractor Osseo MN, Crawler Welding  Mankato MN, Northern Engine has couple of sites in the US.
 Unsure of where you are located . also can try rock and dirt web site for adds for salvage or parts and track shops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 6:54am
I am located in south western New York state. I don't know of any track shops. I used to get catalogs from people selling crawler parts but they are out of business. I tried unsuccessfully on the internet. I spent a lot of time reading internet hits that were not relevent to crawler chain pins & bushings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 11:13am
Are you looking for just pins and bushing or full group? If just parts you will still need to find shop with track press . Has to be shops in area somewhere around you that do the work. PA and OH have to be places where dozer parts can be found .
 Berco of America Aftermarket, WI
W229 N1420 Westwood Drive
Waukesha, WI 53186
Phone: 262-524-2222
Fax: 262-524-2230
Contact Us
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 11:19am
another listing for AC parts for many machines
[TUBE]UyF_b4tlEQk&feature=player_embedded[/TUBE]
Edited by Coke-in-MN - 28 Oct 2011 at 7:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 5:56pm
I have never used a track shop. Years ago I did pins and bushings on my HD5. I fabricated a portable press using a hydraulic cylinder and a porta power. I removed the master pin and grousers on portions of the links and replaced the pins and bushings without removing the chain from under the machine. I moved the machine back and forth to accdomplish this. I also did a small International using a modified arbor press. I'm going to purchase a complete set of pins and bushings. I will consider buying used chains. Thanks for the information.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 6:36pm
there is a set of chains with idlers and drive sprockets on e-bay. they want about 3200+/-, can not remember the last bid. they were loader grousers that looked in very good condition. if you find a set of pins and bushings, please post where you got them as i have tried all mentioned places and all have said discontinued. good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 6:41pm
I have had a couple tracks redone but don't quite understand how you did this as you need to separate the track by link to be able to push out the bushing as it is longer than the one section of the links so it's end indexes into the next link. only short bushing is the master bushing and that uses a cup washer on its ends to mantain space. They can push the pins out while removing just one set of track bolts but require the removal of full link to put in new bushings and pins.
 IH track also has the same dementions as the AC track used on HD5/HD6
 Site with some specs :
Edited by Coke-in-MN - 28 Oct 2011 at 6:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 6:49pm
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 11:30pm
Intertractor iTm also make HD6 tracks rollers and rims; as our iTm dealer in NZ sells them. Was told NZ2500 per chain which is approx US 2000
tits tyres and tracks
they all cost you money
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 2:09am
Guys: Has anyone taken a crack a machining their own Pins and Bushings by purchasing the stock and machining them on their  metal lathes.  I know - time consumptive, but thinking in worst case scenario  when nothing is available, or said to be "not available" this could be done over a winter.  Just a thought.
Kind of ironic that rolls and rims are available in NZ but not USA?
Merv - Love the tag line - sure is true!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 8:49am
I pushed the pins out of about 6 links beyond the link to have the bushing replaced. I was able to spread the links appart enough to remove the bushing where it enters into the link. In situations where this did not work I cut thru the old pin and bushing to separate the 2 sides of the link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:20am
As the bushings and pins are heat treated and have a Rockwell hardnesss spec it would involve heat threating the parts also .
 The inside bore of the link also has to match the bushing for a press fit clearance, then the pin is also a press fit clearance into other end of link
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:59am
Coke in MN
I agree that there is a tolerence and hardness spec that would be dificult for an individual to produce pins and bushings. If there was enough volume perhaps some CNC shop could do it. It would have to be more than the one set that I'm looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 11:15am
Thee are tracks out there somewhere , its just a matter of finding them . Places like Thill Track and Tractor may have a lead and even though they are in Eau Clare WI, they may find a set in your back yard through their contacts and locator system.
 If the HI tracks will fit but pads won't there may be a set of used or new IH tracks setting around also.  I had Northern Tractor in Osseo MN find a set of pins and bushings somewhere to put in my HD4 rails . They also had a set of HD6 track I bought for my HD5G project I sold .
 for a small shop to make up the parts would be above the cost one would be willing to pay I believe . It might be cheaper to have them shipped from NZ but then if they are in NZ they must be here in the US also, someone has them.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 5:11pm
Our track shops in New Zealand import from the manufacturers in Europe. It cannot be too difficult for suppliers in the US to do the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 6:23pm
BER$CO is the largest prodcer of name bran replacements , which is Italian , the sites I looked up also had links to China for replacement but they may be just for the late machines .
 The Berco rep I talked to for the area here was like talking to a moron. I had found a set of track at Eldron Equip in WI that he had bought at a auction I took the numbers and sizes and wanted to see what they matched to but the rep would not tell me what they were for or what the specs were on the track I wanted ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 7:15pm
Sadly Coke, those morons are everywhere these days. The manager of the track shop I use (same one Merv made enquiries with) prints off any track specs we want. He has specs for all AC stuff. Maybe I could find out his European contacts. I think he once told me Berco would not do small orders. They set a minimum quantity each of his orders had to be
This page was generated in 0.222 seconds.
