Hd6g loader valve needed
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g loader valve needed
    Posted: 03 Jan 2021 at 1:57pm
Anyone have or know where a loader control valve for a hd6g? Older serial number as it has a Buda engine. Thanks
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 2:46pm
I should have some parts for control valve HD6
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 7:36pm
Hector, do you have the whole valve? I would also be interested in just the relief valve section of the valve. I am working on one that has low hydraulic pressure and want to chance the valve and spring to see if performance improves before replacing the pump. If so, how much? Thanks
This page was generated in 0.127 seconds.
