Hd6g hydraulic leak
yrageel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yrageel Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g hydraulic leak
    Posted: 08 Aug 2019 at 10:49am
Hd6g crawler loader leaking hydraulic fluid from what appears to be around pump on front of engine, what's the best way to get access to the pump? Does the hard nose have to come off? Looks like belly pan doesn't give access to pump either! Help!!!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 11:40am
can access through grill, but removing the bumper will make things alot easier.  likely stuffed full of dirt in there and rubbed a hose through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yrageel Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 1:47pm
Thanks
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 11:17pm
The front hard nose tilts forward. It gives you some room.
This page was generated in 0.547 seconds.
