Hd6g clutch problems |
Page <12 |
gemdozer ![]() Orange Level ![]() Joined: 17 Sep 2009 Points: 1039 |
I am located STE-JULIE near MONTREAL CANADA
Jhilton69 ![]() Bronze Level ![]() ![]() Joined: 01 Aug 2023 Location: Lyerly Georgia Points: 79 |
How hard is it to replace the clutch break pads?
I've looked at my book several times now. Here's the million dollar question counterclockwise from the front of the loader or the seat of the loader?
The countercluch wise when you are on seat if she is to much adjusted
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1262 |
I adjusted the clutch on my Son-in-law's HD5G last summer, it has the same clutch as yours. It only required two notches to get it tight again, but since yours was run without having the adjustment locked in place, all bets are off ![]() Clockwise while sitting in the operator's seat tightens the clutch.
I've been driving the inner ring clockwise for a while now its slow going for me since it's hard to get in there. That would make the outter notched ring go on the counterclockwise direction to loosen is this correct?
Sometimes I get easily confused ![]() Perhaps a picture may help? ![]() |
Thos isn't the clutch in my ol gal. Mine has a outter ring like a castle nut facing the rear. And a flat surface on the inside thay I've been turning
This is a AUBURN cluch on photo and you should have a ROCKFORD cluch and it could be the tread on adjusting ring or the backplate treade are bad or it could be the 3 cam bearing are bad worn
Ahhh... let's try this one ![]() |
Page <12 |
