Hd6g clutch problems
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 9:03am
I am located STE-JULIE near MONTREAL CANADA
Jhilton69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 1:00am
How hard is it to replace the clutch break pads?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 9:13pm
I've looked at my book several times now. Here's the million dollar question counterclockwise from the front of the loader or the seat of the loader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 8:51am
  The countercluch wise when you are on seat if she is to much adjusted
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 9:02am
I adjusted the clutch on my Son-in-law's HD5G last summer, it has the same clutch as yours. It only required two notches to get it tight again, but since yours was run without having the adjustment locked in place, all bets are off Big smile
Clockwise while sitting in the operator's seat tightens the clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 11:20am
I've been driving the inner ring clockwise for a while now its slow going for me since it's hard to get in there. That would make the outter notched ring go on the counterclockwise direction to loosen is this correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 1:32pm
Sometimes I get easily confused Confused
Perhaps a picture may help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 2:28pm
Thos isn't the clutch in my ol gal. Mine has a outter ring like a castle nut facing the rear. And a flat surface on the inside thay I've been turning
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 6:09pm
This is a AUBURN  cluch on photo and you should have a ROCKFORD cluch and it could be the tread on adjusting ring or the backplate treade are bad or it could be the 3 cam bearing are bad worn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 7:12pm
Ahhh... let's try this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 3:40pm
Ok looking closer at tje poc ya its what mine is. I've been beating on ot for a week now and it won't turn. Im at a lose any help would be appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 5:24pm
The only unit I have experience with is the Auburn clutch so I'm not much help. The Auburn clutch has ramps that make it easy to decipher, but the Rockford clutch isn't readily discernible from the drawing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 5:50pm
If you can not adjusted your cluch it could be the cams bearings ,links and pines,traide on adjusting ring,brooking springs you better pull out the cluch assambly and you will see the probleme.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 11:18pm
I'll get a license tomorrow in the light maybe it'll show something yall can see to help me. I would answer zoo er but for some reason it stopped emailing me with replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2025 at 1:11pm
Here's what I got going on. I tried to put pics up but it keeps telling me the file is to big. How do I ad them
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 6:37pm
You only need the clutch brake to stop the driveshaft from turning when the clutch is disengaged in neutral to stop gear grinding. Mine was shot and used it just fine. As far as the rod goes, it come out of the transmission and goes to the right side of the clutch fork shaft. Main clutch rod goes in the left. There is a block in the end of the shaft that the rod goes in. When clutch is engaged the rod comes back and locks the transmission in whatever gear you put it in to eliminate coming out of gear. Plunger bellows go bad and leak sometimes. If rod is disconnected it could make it so it will not shift, will not stop the clutch from disengaging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 8:15pm
It ran fine with the rod off before it doesn't look like its been attached in years. I can't pull the clutch lever back that's my problem. Since I've been down with my neck I've had to have my buddy fo the work on it. He drove tje center clockwise to the point it won't turn anymore. I told him yesterday that maybe we should go counterclockwise and see what that does.
