Hd6g clutch problems |
Page 12> |
Jhilton69
Joined: 01 Aug 2023 Location: Lyerly Georgia Points: 86 |
Topic: Hd6g clutch problemsPosted: 16 Jul 2025 at 10:04pm |
Hey yall just got back up from flordia. Put my brother in law on my ol gal and now the clutch won't engage. I figured he knew what he was doing since he runs a crew of asfault guys. I rode with him at first and he got it I thought. After an hour or so he messed her up. When I pulled the floorboard panels up I noticed a rod on the right side that moves with the clutch handle bit it's not connected to anything and I can't find any information on it. Figured I'd see whatbuall think before opening her up and adjusting the clutch on her. Please help.
gemdozer
Posted: 17 Jul 2025 at 7:02am |
The right side rod is the plunger shifting lock
Jhilton69
Posted: 17 Jul 2025 at 10:55am |
Thank u what does it go too? I haven't found anywhere it hooks up too. Does it affect the clutch engagement?
gemdozer
Posted: 17 Jul 2025 at 12:53pm |
THE rod should be connect to a other rod with a boot on and she is going in the front transmission shifting housing and this rod is loock the transmission in gear when the cluch is angaged and this should affect the cluch.
Jhilton69
Posted: 17 Jul 2025 at 8:58pm |
I searched around and couldn't find any other rod for it to hook too. I didn't get a chance today to do a pull test on the cluth lever gonna do that tomorrow.
Jhilton69
Posted: 18 Jul 2025 at 1:08pm |
Well done my pull test took a lil over 35 pounds to pull the lever over. Any ideas?
gemdozer
Posted: 18 Jul 2025 at 2:22pm |
The master need 25lbs to 30 lbs maximum and the cluch should angage with a distinct over-center snap (engine stop)
Jhilton69
Posted: 18 Jul 2025 at 7:56pm |
Ya i can feel it snap over like it's supposed too. I got tje floorboards out and when pulling the lever back everything with the exception of that rod on the right side looks good
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4875 |
Posted: 19 Jul 2025 at 11:40am |
I am lost as to what is not working.
There is rod that locks the shifter up when the clutch is engaged. Unless that is released it should not come out of gear. Is that the trouble?
Jhilton69
Posted: 19 Jul 2025 at 12:37pm |
I can start her in gear to move her around to stop i just shut her down
Jhilton69
Posted: 19 Jul 2025 at 10:36pm |
It acts like it's not engaging the clutch when the lever is pulled back. But when I checked the pull it was just over 35 pounds. The floorboards are out and watching the levers it looks like it's working. Bit it won't go in gear when running just grinds
Codger
Posted: 20 Jul 2025 at 5:54am |
When you pull that handle back you are engaging the main clutch and if transmission is in neutral, it is going to grind if you attempt to put the transmission into a gear. If that rod mentioned were operating correctly, you would not be able to move that shifter with the clutch engaged.
With the handle pushed forward, the clutch is released. You can now shift gears in the transmission. With the transmission in a selected gear position, and the handle pulled back engaging the clutch, the tractor should move and you should not be able to move the transmission shift lever. If I am reading your postings correctly, the rod mentioned is not connected to the shift mechanism and laying loose. When you push the clutch lever forward, the main clutch is not releasing and continues to spin the transmission? This is either a warped clutch disc, pressure plate, (clutch cover) or sections of the friction material have broken free from their mountings and are binding between the flywheel, and pressure plate of the engine causing a frictional "drag". If clutch adjustment does not solve the issue, clutch apparatus replacement is your next option along with bushings, and any linkage points involved. From this vantage point I would say it is probably time to replace the clutch assembly.
That's All Folks!
gemdozer
Posted: 20 Jul 2025 at 6:15am |
When you desangage the master cluch the brake cluch have to stop the cluch turning for angage the transmission
Codger
Posted: 20 Jul 2025 at 6:38am |
Those have a clutch brake incorporated? Have never worked on one myself.
That's All Folks!
Ray54
Posted: 24 Jul 2025 at 2:49pm |
General Gear out of Boise Id has parts books and service manuals on line for most older crawlers. They have HD 6 books as just looked at them. They have been the go to for steering clutch parts for a long time. Looks as if they may have the wear parts for the master clutch as well.
Jhilton69
Posted: 24 Jul 2025 at 3:26pm |
I've owned and driven the machine for the last 2 years with no problem like arising. I did read that letting her set with the clutch disengaged for a long period of time will cause the disk to stick to the flywheel. I did start her in low gear and drove to a tree put her in full throttle against the tree. All she did was dig a big hole from the tracks.
Jhilton69
Posted: 24 Jul 2025 at 3:28pm |
Now that u mentioned that I don't think I see the driveshaft stopping while clutch disengaged gonna check that after I get my backhoe finished up today
gemdozer
Posted: 24 Jul 2025 at 8:33pm |
Like I said the brake cluch is not working
Jhilton69
Posted: 24 Jul 2025 at 8:51pm |
Ya im gonna check that tomorrow almost got the backhoe done. Pulling that shifter out has been a pain in the backside. I finally got it out tried burning the old wire loom out but that failed lol even with has poured in it. Lol
Jhilton69
Posted: 25 Jul 2025 at 10:05pm |
Well im stuck now. Worked a li l on my ol gal this morning and didn't end well. I tried adjusting the main clutch by a few turns and now I aint got enough strength to pull the lever back. I was trying going to get it down to 30lbs but somehow ending up making it worse. I know to add more pressure turn it clockwise so I turned it counterclockwise. Any ideas would be helpful please.
Adrian
Joined: 26 Apr 2022 Location: New Zealand Points: 13 |
Posted: 25 Jul 2025 at 10:22pm |
I have just looked it up and counterclockwise tightens it. Also if you need to buy parts it should be an Alburn clutch. Good luck I hope you get it sorted.
Les Kerf
Posted: 26 Jul 2025 at 7:29am |
Ummm... please define 'a few turns'. This type of clutch typically needs only a few 'notches' of movement on the adjuster gizmo.
gemdozer
Posted: 26 Jul 2025 at 11:11am |
The HD5-HD6 use a AUBURN and some use ROCKFORD cluch and when these are to much adjusted you need to desajusted and try to readjusted 2 or teeth and try to angaged the cluch lever until you have a good snap and am still have some parts for.
Jhilton69
Posted: 26 Jul 2025 at 3:08pm |
According the the operating and field maintenance it says to go clockwise to tighten. It's an original book not a remake. Just looked again and it clearly says to turn clockwise. I would think it's the same as all equipment the direction would be from the drivers seat.
Jhilton69
Posted: 26 Jul 2025 at 3:10pm |
I know where i screwed up when I was working on her it was late in the night after a long day. After adjusting her i forgot to lock the plata in place and I started the engine and tried the clutch. I believe that's what tightened her down so tight.
Jhilton69
Posted: 26 Jul 2025 at 3:11pm |
Les Kerf
Posted: 26 Jul 2025 at 4:01pm |
Whee! That will do it fer sure
Jhilton69
Posted: 26 Jul 2025 at 5:35pm |
That's makes me not feel like a fool at least. Anyone knowbof a place to get the clutch break pads at?
gemdozer
Posted: 26 Jul 2025 at 7:53pm |
All the breake shop can make these breake pads and am still have some parts for transmission ,final drive,motor,master cluch,stering cluch,hydrolic
Jhilton69
Posted: 27 Jul 2025 at 8:34am |
Page 12> |
