hd6b |
dustydoo
Topic: hd6bPosted: 02 May 2014 at 6:40pm |
While adjusting wet clutch on dozer dropped a bolt and lockwasher in housing!!! What are my chances of finding it with a magnet and flashlight???????????
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Posted: 02 May 2014 at 7:29pm |
Just keep fishing - surprised what one can snag - might try putting something over magnet so it doesn't stick to the housing and just the bolt and washer .
I have fished tools out of rear housing , parts out of dry clutch housings with magnets GOOD LUCK
dustydoo
Posted: 02 May 2014 at 7:32pm |
Thanks coke I think I'm going to need all the luck I can find
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 11 May 2014 at 7:37pm |
So.......how did the fishing go? Darrel
dustydoo
Posted: 11 May 2014 at 8:47pm |
found the bolt never found the lockwasher !!!!!!!!!!!! hope I never do
darrel in ND
Posted: 11 May 2014 at 10:03pm |
I would think a lock washer in there would be pretty harmless. Darrel
dustydoo
Posted: 12 May 2014 at 2:02pm |
I'm sure hoping so
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 12 May 2014 at 3:48pm |
Will be in the clutch oil sump at some stage if not already there. not difficult to get it out of there with the sizable drain plugs AC use
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35696 |
Posted: 12 May 2014 at 3:55pm |
My 7G has magnetic drain plugs, did these? If do will stay there until you pull the plug.
Mactractor
Posted: 12 May 2014 at 4:23pm |
They didnt put magnetic plugs in those engine clutch sumps Dave, but they used the same thread for the plug as on the powershift trans and most other drain plugs on the machines, so you can put a mag plug in if you want.
dustydoo
Posted: 12 May 2014 at 8:36pm |
thanks guys making me feel better
