HD6-B Tensioner Screw Thread Size
jwoods View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwoods Quote  Post ReplyReply Direct Link To This Post Topic: HD6-B Tensioner Screw Thread Size
    Posted: 25 Jul 2021 at 1:36pm
Hello All,
Had to cut out the old threaded tensioner (22-3/4 length), heat the yoke and extract the threaded portion.
Two options so far:
1: Find a boneyard donor
2: Find the correct thread/pitch bolt and weld onto the remaining hex stem.
 Looks like 1-5/8 x 5.5 pitch, but figured would throw it out here; also if anyone has a source for either.
Thanks, -Joe
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 9:25pm
We might have what you need....we're a long ways away...California. Hector...(gemdozer)...will probably be able to help you.  He's got access to a lot of those parts. He'll see the post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwoods Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 5:23am
THanks Mel, and...you are correct.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 12:25pm
I turned a length of stock to thread - then welded it to the end of the hex part on a HD5B  - the lock collar was bad though so had to find a nut to fit end of new turned thread .
 If I were to do it again I would find a hydraulic ram and make it a grease type adjuster .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwoods Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 7:09am
Thanks All,
I was able to find a used replacement screw.
