Hd6 water pump seal
Trackmader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trackmader Quote  Post ReplyReply Direct Link To This Post Topic: Hd6 water pump seal
    Posted: 20 Mar 2025 at 5:03am
Anyone have a lead on a seal for the water pump. In my manual its the type 2 water pump. It all looks good except the seal fell apart.
That was the first time i needed a 3/4 set and hydraulics to change a water pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trackmader Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 5:04am
Forgot to mention its a 1956 hd6 with hardnose and cage.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 6:05am
I ceased rebuilding pumps a long time ago and started sending them to a place in Houston, TX. They can repair most anything I've found with quick turnaround.
www.waterpumpkits.com is their website.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trackmader Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 6:17am
Website is not available. Domain for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 6:36am
Hope they are still around. I have their contact information at the shop and will look later today.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 6:39am
That's All Folks!
HD6 Merv View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 11:50am
HD6 with 6000 engine water pump seals were available from Minpaar. Came is a Agco badged box.  You need the updated part number starting with a 7.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 11:56am
Do you know the part number
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trackmader Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 3:32pm
Part number appears to be 106ml or us seal ps-2161. Will update if it works.
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 10:15am
As per Mervs comment...the part number for the complete pump looks to be 74359281......the new number is 74320996..that number for a complete water pump assembly shows to be available at Minnpar for 513.00 $eal assembly 74507091 also shows available for$22.00...didn't look at any of the other parts for availabiliyy.  As per Codgers comment...we quit rebuilding those years ago...and would opt for a new or rebuilt one.   FYI...we have a master numerical index to update part numbers that were changed    send me a part number and I can check it....It's helpful when trying to go to Minparr...also have a book of discontinued numbers
Edited by AC Mel - 21 Mar 2025 at 10:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 11:20pm
Thanks Mel. We can help you with seal
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2025 at 12:40am
FWIW
Looks like this one should go from a makers part number to a Timken equivalent.
I'll see if I can find the title of that IBR one, as it does multiple bearig makers.
For even more conveniencent- the FA 10 parts book has a table in the back that goes from Fiat numbers to standard bearing size talk
Edited by Ian Beale - 22 Mar 2025 at 3:38am
