HD6 Trans and final drive lube
Detrot1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Detrot1 Quote  Post ReplyReply Direct Link To This Post Topic: HD6 Trans and final drive lube
    Posted: 29 Mar 2024 at 1:36pm
I saw in here somewhere that said you could use hydraulic oil everywhere but the crankcase?
My manual said SEA 50 above 32 degrees SAE 30 below 32 degrees.
CAN I run hydraulic oil in my trans and final drive? SAE 50 is 200 dollars for 5 gal. Will need 11 gals according to my manual. 5 in trans 6 in each drive.
What are your thoughts?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 2:30pm
80-90 would be better for trans and bevel gear compartment.  can run in finals also
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 2:55pm
I will not give a recommendation because i dont know.. But "MOST" hydraulic oils are in the 10 - 20 - 30 viscosity range..
50w engine oil is comparible VISCOSITY WISE to 80-90 gear lube or ISO 150 - 220 industrial gear lube...
Edited by steve(ill) - 29 Mar 2024 at 2:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 3:15pm
AMAZON....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 3:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Detrot1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 5:37pm
Thank you for all of your replies.
I will stay with SAE 50.
I didnt think it was a good idea, and couldn't find the post I saw. While the hydraulic oil would be convenient, it would just not be best for this application. Thank you all!
Edited by Detrot1 - 30 Mar 2024 at 6:33pm
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 7:18pm
AMAZON....
This product works well in Roadranger transmissions both older, and newer.
That's All Folks!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 8:13pm
I used Mobile DTE - Extra Heavy grade in transmission as it also lubes the ring and pinion  area . It is 1100 Sabol Second Universal grade (pour rate) which is 50 weight or slightly heavier
In finals a heavier oil like the 90 or 120 weight gear oil
Edited by Coke-in-MN - 30 Mar 2024 at 8:14pm
Adrian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adrian Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2024 at 7:23pm
If the oil in the final drives is to heavy it won't get through to the outer bearings. I think it's easier to use that right grade than replace final drive bearings later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 2:42pm
the outboard bearing on axle is a link belt roller bearing which is suppose to be lubed by rifle drilling in axle - seen a lot of machines where that housing is drilled to install a grease zerk in casting , drilling where the flat raised area is . Then using gun grease to lube it
This page was generated in 0.273 seconds.
