HD-6 lubricant
Ullrich Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ullrich Farms Quote  Post ReplyReply Direct Link To This Post Topic: HD-6 lubricant
    Posted: 08 Jun 2020 at 9:23am
I am servicing an HD-6B. What is the recommended track roller lubricant?
Thanks Sandy Ullrich Haskell OK
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 10:23pm
I put corn head grease in mine. I'm not sure that is the recommended stuff, I no longer have an owners Manuel to look it up for you. Sorry.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 8:10am
This is from the HD6 manual, serial 1-13321. Viscosity-120-185 @130 degrees. The description takes up a quarter of the page. Corn Head grease is a good choice. I bought it from Farm Oyl in MN.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 8:20am
However, at 210 degrees it should have a viscosity index of 45-58, when looking at the latest FA manual.
Curt Anderson
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 5:11pm
A semi-fluid or flow able grease as it is not pressure fed but placed in cavity by means of pump tube and filled to a point grease is freely flowing from the cavity within the roller . As Timken cone and cup roller bearings are used within the rollers .
This page was generated in 0.081 seconds.
