HD6 Idler Bearing Number Needed Please
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: HD6 Idler Bearing Number Needed Please
    Posted: 19 Feb 2013 at 1:15pm
Guys: Am progressing work on the front idler and am in need of the Timken or National Bearing number for the front idler.  The machine is an early 1958 model so is the early idler.  I called Minn Parr to see what resources they have.
Likelihood is that I will need a four bearings and four seal kits to do both sides and each idler.  I can see about 1/4" deflection between the end cap and the idler housing on the rail.
Any help very much appreciated!
Thank-you...Orangeman
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2013 at 3:15pm
I could find the cup at my local bearing house but the timken cones they had no source for . I ended up getting them from a small track shop who also had the seal and a source to order the cone.
 Unsure of who in New York area would have them but you can check to see if you have any small dealers or track shops around your area.
 can also try Thill Track and Tractor in Eau Clare WI , or Northern Tractor in Osseo MN , another might be Northern Engine in Duluth MN -  or Crawler Welding in Mankato MN
pokemonjxc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pokemonjxc1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2013 at 12:15am
 If you would like get platinum throughout Whoa and also the recognition along with awareness that come and also the idea, and then you really should stop aiming to accomplish goods yourself in case very easy purpose.
