hd6 fuel pump |
michale34
Topic: hd6 fuel pumpPosted: 31 Jan 2014 at 11:41am |
I got a friend of mine with a hd6 he took the injector pump off to go get tested at a diesel shop all I know he said they lost it or don't have it ? anyway will it has the top injectors 6000 engine I know were theres a 344 buda side injector hd6 is does anyone know if that pump will work on the 6000 engine
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 31 Jan 2014 at 12:50pm |
interesting question michale. Am curious myself. Both are bosch psb pumps. Both are different part numbers, but wether they just update I don't know. I would have exploded at the fuel shop. You don,t 'lose' fuel pumps; and if you did best you replace it.
tits tyres and tracks
they all cost you money |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 31 Jan 2014 at 1:27pm |
I have the PSB pump off my donor HD7G, if he ends up needing one and it would work as a core to build I would consider selling it as a core. It was open for a extended period before I got the tractor.
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 31 Jan 2014 at 5:45pm |
I had to look around this area with our AC 45 grader.
Not sure on the 344, but they played tunes on the 516's. There are 9 and 10mm plungers, and there are different injection timings. 9mm's were 32 degrees, 10mm 28.
I got this from a HD 11 parts book and service manual, but don't have access to them any more.
Jensales have an Allis tech manual on the PSB pumps that might help. Edited by Ian Beale - 31 Jan 2014 at 5:49pm |
Ian Beale
Posted: 31 Jan 2014 at 5:46pm |
Should add that that
Edited by Ian Beale - 31 Jan 2014 at 5:48pm |
gemdozer
Posted: 01 Feb 2014 at 6:01am |
I have 3 injection pump for 344 with different number and one is rebuilt with # 4348762
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 01 Feb 2014 at 9:22am |
My HD6 book says # 4348762 is for engines prior to 6-10368
# 4349851 is for engines after however the injector plumbing ilustrated with these pumps is for the HD344 engine. My HD7G book says #74354230 for the 6000 & 7000 engines |
michale34
Posted: 01 Feb 2014 at 9:05pm |
He said the fuel shop he took the pump to kelp putting him off saying they were backed up and trying to find parts for it he said next thing he knew they were closed up and someone told him the pump wasent left in the building and the owner pulled the over 30 day terms on him sounds like they sold his pump to me or tore it up and didnt want to replace it no wonder they went out of business that same place charged my dad 140.00 dollar a piece to rebuild injectors for a hd6g in 1984 he about had a stroke
rnugen
Posted: 21 Jan 2020 at 11:06am |
I need an injection pump for an Hd6E. does anyone have a good core or a pump I could purchase. I have 3 of these dozers and one is almost brand-new and now has a bad injection pump.
Thanks Ron 208-305-6995 |
gemdozer
Posted: 04 Feb 2020 at 10:23am |
I have a injection pump PSB4A 100G-5811A3--4354233
rnugen
Posted: 04 Feb 2020 at 10:26am |
Thanks for the replay. Do you know if it will fit and work on an HD6E? I don't know very much about the numbers on the injection pumps.
Thanks Ron |
gemdozer
Posted: 04 Feb 2020 at 6:04pm |
This pump should fitt and have a part number on the head HD6800A and this pump was on motor with bad motor HD6
rnugen
Posted: 04 Feb 2020 at 6:15pm |
How much do you want for it? I am interested. I found one in California that is supposed to good for $500. Let me know, I need one.
Thanks Ron 208-305-6995 is my phone. You can text on that number too. |
Nugenrw
Posted: 05 Feb 2020 at 3:49pm |
I finally got back to the posts. Can you let me know if you are getting these posts. I sent 2 replies and haven't heard back. I would like to buy the injection pump from you.Thanks
Ron. |
