HD6 final drive noise? |
Tb4020
Joined: 13 Aug 2012 Location: thumb of Michig Points: 3 |
Topic: HD6 final drive noise?Posted: 13 Aug 2012 at 7:06am |
Hi, new to the board! Using my HD6 yesterday and it started making noise in the right rear and slipping, I know it's probably not good but any suggestions?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 13 Aug 2012 at 9:07am |
Depending on the noise , clutch slip, bad bearing - allowing the teeth to jump of reduction gears, broken axle, or ?
Pull inspection cover on clutch housing and start there . Raise tractor so both track off the ground and see what happens to each side or the noise heard when each track is individually not powered by other side .
Tb4020
Posted: 13 Aug 2012 at 10:39am |
Almost sounds like a bearing bad and teeth jumping. I was just hoping for a silver lining.
gemdozer
Posted: 13 Aug 2012 at 12:18pm |
Remove the final drive drain plug from side noise and check if you have some metal pieces in oil it could be a pinion bearing
