HD6 final drive gears
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Topic: HD6 final drive gears
    Posted: 10 Nov 2011 at 5:45pm
HD6B 20771 I Need bull gear 51 teeth #051400 and pinion gear 20 teeth # 049886 If any one has these for sale, Email or call 660 828 4310   MACK
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 5:48pm
Might have a set that are worn at angle , where are you located .
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2011 at 3:48pm
I check tomorrow how many gears and pinions am still have
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 5:21pm
mack, your pm box is full and you need to delete some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 5:25pm
mack, i ahve them also, located in pa. where are you located as shipping may be cheaper from coke or hector. let me know.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 7:45pm
Thanks guys I have a set on the road befor I heard from you guys. If I need something else I will let you guys know. Thanks   MACK
