hd6 dozer clutch |
michale34
Topic: hd6 dozer clutchPosted: 15 Aug 2016 at 12:45pm |
Im looking at a hd 6 dozer with a oil clutch the guy said it wont stop pulling when its in gear I know my dads old 6g wont pull at all if the oil is not flowing found that out a few years back after changing the oil filter . could this be the disk in the clutches being warped
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35692 |
Posted: 15 Aug 2016 at 5:59pm |
Clutch facing may have separated and stacked, not much clearance in the flywheel to pressure plate and a section of separated disc would keep from disengaging. Could also be a spline step seize where the disc just cannot get off the flywheel or pressure plate.
gemdozer
Posted: 18 Aug 2016 at 8:51am |
If you have a ROCKFORD wet cluch maybe the small camshaft are bad
michale34
Posted: 18 Aug 2016 at 12:58pm |
Allis Chalmers HD6-E http://monroe.craigslist.org/hvo/5723953380
