HD6 Crawler - broken leaf spring under the engine |
Andymac
Joined: 16 Apr 2023 Location: New Zealand Points: 18 |
Topic: HD6 Crawler - broken leaf spring under the enginePosted: 23 Jan 2026 at 5:24pm |
Hi All,
I've broken 2 leaf springs on my HD6, does anyone know if there is an aftermarket spring that can be purchased? I'm in New Zealand. Is it possible to slide out the 2 broken ones and replace them without taking the whole leaf pack off? Any tips or tricks on the best way to do this would be appreciated. Thanks in advance....
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 582 |
Posted: 24 Jan 2026 at 4:57pm |
If you haven't already done it, you might also post in the Construction Equipment section
Andymac
Posted: 24 Jan 2026 at 5:10pm |
Thanks, I’ll do that
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 25 Jan 2026 at 7:47am |
I have no idea of what is available in New Zealand, however around here there are many shops that make truck springs. If you have something like that, you could take the broken pieces to them and they could make new ones that match the size and curvature.
Posted: 25 Jan 2026 at 3:07pm |
I assume they are a stack of leaf springs. If so, there is a center bolt that draws the whole stack of individual springs tight together in the center. No way to repair in-chassis.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4870 |
Posted: 25 Jan 2026 at 7:55pm |
Is this a dozer, loader, or just farm tractor. Loaders seemed to have more trouble than the others. They just put a solid bar across later model loaders.
Neighbors bought a Cat D6 with broken spring, found an older model D6 to buy a spring from. It was a bit lighter, but being somewhat careful it never broke. So if you know of any old parts machines even if not a HD 6 check them out. Might be close enough.
Andymac
Posted: 26 Jan 2026 at 4:52pm |
Thanks for your answers, I found a local company that will make me a new one. To clarify its an HD6 dozer that I have
