HD6 Crawler - broken leaf spring under the engine
Andymac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andymac Quote  Post ReplyReply Direct Link To This Post Topic: HD6 Crawler - broken leaf spring under the engine
    Posted: 23 Jan 2026 at 5:24pm
Hi All,
I've broken 2 leaf springs on my HD6, does anyone know if there is an aftermarket spring that can be purchased? I'm in New Zealand.
Is it possible to slide out the 2 broken ones and replace them without taking the whole leaf pack off? Any tips or tricks on the best way to do this would be appreciated.
Thanks in advance....
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:57pm
If you haven't already done it, you might also post in the Construction Equipment section
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andymac Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 45 minutes ago at 5:10pm
Thanks, I’ll do that
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 8 minutes ago at 7:47am
I have no idea of what is available in New Zealand, however around here there are many shops that make truck springs. If you have something like that, you could take the broken pieces to them and they could make new ones that match the size and curvature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 48 minutes ago at 3:07pm
I assume they are a stack of leaf springs. If so, there is a center bolt that draws the whole stack of individual springs tight together in the center. No way to repair in-chassis.
