Hd6 B dozer
Roy mcghee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roy mcghee Quote  Post ReplyReply Direct Link To This Post Topic: Hd6 B dozer
    Posted: 08 Jan 2019 at 8:34pm
Anyone know the belt numbers that
go on this dozer? I have the old ac part numbers but they aren't any good....it has the 344 Buda engine, any help would be great.
Edited by Roy mcghee - 08 Jan 2019 at 9:15pm
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 12:51am
IIRC you need to put a "7" in front of the old Allis number these days
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 5:40am
What are the numbers you have? Someone might have them crossed in their notes if they know what your numbers are.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 6:44am
Also, if you have the old numbers, post em in a want ad in the classifieds section of the forum here. A few folks on here have NOS parts, and may have the belts you need. Darrel
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 3:23pm
If you have the Buda HD344 as opposed to the Allis Chalmers HD344 aka Allis Chalmers 6000 motor the belt size is no longer produced. That is what I found when my HD6G needed belts. The Buda motor has the horizontal injectors and you have to remove the crank driven hydraulic pump to change the belts.
Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 7:16pm
For the Buda 516 in an AC Forty Five grader (which I think is the same engine front end) ours uses C 60 for the fan and C53 for the pump - that with an alternator fitted though.
