HD5G Side Shields
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: HD5G Side Shields
    Posted: 31 Jan 2010 at 9:45pm
I need to make some side shields to protect the engine (fan & radiator) from tree limbs when backing the machine in heavy brush. Had a small limb get between fan belt and drive pulley.........broke the belt.......guess I got off easy.  Anyway, I'm hoping someone here on the forum has either built some or seen some factory made and can offer suggestions on how to build (or not) a pair.
Why is there never time to do it right the first time, but always time to go back and fix it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 10:32pm
Here is a pic of factory side shields. These came off a 5g and i haven't put them back on. I often thought i should so i don't get the branches in by the engine. These are made out of 16 gauge steel  and the recessed part by the latch is made out of a little heavier steel. The hook n the lip thats on the egde of the hood and the latch hooks on the fender that is along the engine. I could probably bend a set up for you but they wouldn't have the louvers in them and they may cost a little bit to ship.   Hope this helps you out Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 11:03pm
Matt: Thanks for the pics and comments.  I have some sheet steel and expanded metal so will make some in the next few weeks (depending on weather).  I thought about the lip on the hood, but could not think of a good way to fasten the bottom.  Will post some pics  when I get them done..........O_O
P.S.  I saved your pic to my hard drive, so will look at it a few times as I figure things out.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 4:40am
are you willing to sell those? or how about some dimensions please? i think they would be a good addition for forest work. thanks, tim
This page was generated in 0.211 seconds.
