Hd5g parts |
DavidnTenIll
Bronze Level Access
Topic: Hd5g partsPosted: 23 Jul 2016 at 8:31am |
Looking for hd5g engine clutch shaft and front yoke with good tight splines.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 23 Jul 2016 at 4:26pm |
General Gear Please post if you find a new yoke.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 23 Jul 2016 at 6:59pm |
that front yoke might be a problem as I found 1 out of about 8 I checked -
Clutch shaft - around but also hard to find a good one with no wear - couple I had were worn at pilot bearing end as well as splines . check that brass bushing in the throw out bearing area also for wear as that will cause shaft to wobble . I turned a new one from brass bearing I took from metal polishing machine
DavidnTenIll
Bronze Level Access
Posted: 23 Jul 2016 at 7:30pm |
Yep contacted GG but haven't heard anything back yet. Appreciate the responses.
gemdozer
Posted: 24 Jul 2016 at 10:03am |
I have a cluch shaft 19inchs longues and have 1 yoke with U bolts and 1 with joint bolt on yoke
DavidnTenIll
Bronze Level Access
Posted: 24 Jul 2016 at 4:55pm |
Gem dozer I sent you message should be in your inbox. David.
DavidnTenIll
Bronze Level Access
Posted: 27 Jul 2016 at 4:34pm |
Gem dozer sent you message and email to your inbox.
David. |
