HD5G Batteries
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: HD5G Batteries
    Posted: 29 Jun 2011 at 8:08am
I bought an HD5G at an auction Saturday, and hopefully a set of batteries will get it going. It has an alternator on it, so I would assume it is a 12 volt system, is that correct? And the alternator looks to be factory, again, is that correct? And last, since it has an alternator, that would make it a negative ground system, wouldn't it? It has no batteries in it now to use as a reference. Thanks, Darrel
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 8:27am
Yes they are 12v and negative ground my hd5 starts on one big aussie 86 battery
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 12:56pm
The HD5 should have a generator and yes it is 12 volt
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 5:00pm
since you question it's originality, somewhere on the alternator/generator should be stamped voltage and polarity. you can mess up a charging system with wrong polarity. starter does not care but alternator/generator does. one good size 12 volt battery should crank it well enough, that is all i use. good luck
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 8:00pm
It came with two large 6V batteies , one in each side, hooked in series to give 12V pos ground . Came with a generator that had a double belt pulley and used a cut-out relay mounted on generator.
