HD5G Axle Spline Count
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: HD5G Axle Spline Count
    Posted: 27 Feb 2022 at 7:02am
General Gear in Boise lists new final drive seals for 6-splined axles; how do I know what our HD5G has withOUT dismantling?
S/N HD5G 9664
Edit. without dismantling?
Edited by Les Kerf - 27 Feb 2022 at 10:07am
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 7:11am
found this...lost count,
I sure hope someone has a manual with pix for you !!!
My Buda BD153(in ac forklift)  needs rings ...3 ring set OR 4 ring set ??
Same boat, different paddle....
Jay
HD6 Merv View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 10:14pm
All HD5 and HD6 s up to around 14000 serial number had coarse, 6 spline axles for the sprocket. Later HD6 s  had the finer spline sprocket
tits tyres and tracks
they all cost you money
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 9:19am
I am still have some HD5 final drive parts.
                                                    HECTOR
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 9:30am
Looks like we probably have the 6-spline axles unless they have been swapped out for the later type.
Thanks for the help Smile
