Hd5B on ebay
creeperfreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote creeperfreak Quote  Post ReplyReply Direct Link To This Post Topic: Hd5B on ebay
    Posted: 07 Jul 2013 at 2:45pm
http://www.ebay.com/itm/321157576131?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2013 at 2:57pm
Item location:
Arlington, Washington, United States
Ships to:
Local pick-up only
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2013 at 6:57pm
Yep, that's a fer piece for me Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote creeperfreak Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2013 at 6:53pm
closed at $405.00.  hope it went to a good home not the scraper.  why are all the good deals 3500 miles away?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2013 at 10:41pm
I was wondering why all the good deals are on the east coast, west coast and the southern states...  And none close to home.
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2013 at 9:30am
Ok guys thought I should report for creeperfreak that it will not be going to the scrappers but coming to the "ALLIS CHALMERS COLLECTION of REDWOOD VALLEY GRAVEL". After the restoration of the Core family tractor last year we really would like to have one we could drive and not have to worry about scratching the paint. By the photos this tractor appears to have an original vintage Carco blade and some of you might have noticed that the blade trunions are mounted to the swing frame instead of to the outboard bearing cap. Most of the original after market blades were attached to the out board bearing, which if run long enough caused total destruction. It's a gamble for us to, while the purchase price is ok, it's at least a three day trip with fuel and permits probably being three times that much. We're planing on making the trip later next week. I also might post it up on USHIP and see if it generates any interest that would save us money. We'll post pictures as we progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote creeperfreak Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2013 at 1:00pm
Thumbs Up
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 1:12am
Well it sure looks good, as you mention, getting it home will be two or three times more expensive.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 11:42am
Ok guys, this HD5 is safely back at restoration headquarters. Brother Dave his wife Ina and Cookie the dog made a three day trip to Washington to retrieve it. It's a good specimen Carco blade system, we don't have one of those. The right track rail is near new condition and the left rail is 50% (not a problem). Does not steer, covers are of the clutches and it appears that each side has new brakebands,probably an attempt at a easy fix for the steering problem. That's ok I'll find the problem and let you know.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 4:10pm
Now don,t be shy tell us about the other 3 dozers in the background of your 2 pics ! 16B,6E, 11B ??? any prizes !!
tits tyres and tracks
they all cost you money
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 6:26pm
There's a decent HD6g in Kansas City CL for 2500.
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 7:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 7:08pm
You mean I have to type before hitting post.  Same problem on the HD-5, I just wasn't paying attention to a good one right next door.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 8:09pm
Merv, You've seen all those tractors before from different angles. The HD6EP had a broken sprocket shaft like the HD5 earlier. Put  another shaft in but the outboard bearing seal is leaking (was suspicious when I put it back together there might be a problem) so I'm open for suggestions on that one. The 11B lost the seal in the auxiliary drive pulley last year while we were on a wildfire assignment. All those new parts are laying around ready for reassembly (if I can find them still). The 16B was a save from the scrappers last year we took the blade and the rippers off to move it home. It needs a ring and pinion (that one's gonna be awhile)
Lee, Where were you?. We only turned in a complimentary bid on ebay and got stuck with it. Looks like you could have ferried it across the Sound in a couple of hours. We were trying to keep the scrappers honest
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 8:54pm
Also a Allis HD10:
http://kansascity.craigslist.org/grd/3955484865.html
This page was generated in 0.352 seconds.
