hd5b hydraulic pump hydreco
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: hd5b hydraulic pump hydreco
    Posted: 28 May 2017 at 7:25pm
the hits won't stop. I am just about complete with the restoration of my dad's HD5B and I found a small leak at the front of the dozer that just started. I found the hydraulic pump for the dozer leaking slightly out the shaft seal. I have had the dozer in the shop about 1-1/2 years since I started the major restoration. has anyone had this issue that when you started running it again the leak stopped? the pump is a hydreco 2025g1gb. I have several spare pumps but this is the best one. I took one of the spares apart and the way the mechanical seal looks is like it seals better the more pressure the pump has thus I thought that running it might make it better. Does anyone know of a hydreco dealer that I can get parts from? any help is appreciated. I hope this is the last hurtle as I need the machine for some mountain road building. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 4:56am
Tim, check your P.M.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 9:49am
Mine was leaking some and had place look at it that said they could fix anything - NOPE said it was shot beyond repair - ended up putting it back in service - has not leaked since
 I had found a rebuilt Vickers pump for the early HD5 machines but they used a different drive plate which I could not find .
 a 30 GPM pump for the 5G is tough to find as is modifying a new unit to fit .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 7:50pm
278.00 for the seal lit. OMG! I am going to try it as is and see what happens. I have 5 other pumps, all look like they leak at the front seal. if the original still leaks I will rebuild one of them. I have the same part number that is in the 5g parts book, not sure if we just had a lot of them or they are the same as the dozer. I cannot find my dozer book to check the part numbers. anyone have a grade builders (I think that is what it is called) book for the hd5?
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 7:19am
Post a picture of the pump seal. If it is a round shaft seal it could be available from a bearing dealer. I have fabricated shaft seals that I was unable to purchase.
Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 8:07am
believe the output capacity was less on the 5B
 Wear on the 5G pump internals also lead to less capacity - pump on mine use to stall engine when lifting to full height on bucket - would drag engine down quickly if levers were not brought to neutral position - - over 40 years it has gotten to where it's barley noticeable now of any power drain. Wear plates on pump as well as other parts internally allow bypass
