HD5B allis
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Topic: HD5B allis
    Posted: 24 Jun 2011 at 6:28pm
We got this old girl in a bad way they run it out of oil in the right hand side final drive we replaced front idler rolers bearings seals unsesed track adjuster and it is working fine now the littel 2,71 gm run sweet. cheers john
This is were we got it
 from
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:15am
i like it. thanks for the pics, i have never seen a hd5 with a cable blade. i have one that needs the same repair because no oil got to the outboard bearing and ate the shaft. hope to start on it soon. good luck with that awesome piece of iron
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 6:27pm
Watch that upper outboard bearing also , for when that one fails it breaks the rear housing . Seem about 5 machines like that so far that i have looked at.
 Excapt for having soomething uneque in cable dozer I sure would have a set of hyd cyl on it for the blade .
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:01pm
Hi everyone  it is one of the first hd5 built i like the cable blad no hyd problems the winch is taged heil and co road machinery milwaukee and buck eye blade it would have been shipped to australia as is thanks for the tip on the upper bearing i have a grease nipple on it. cheers john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 9:28pm
Had a 5B with a 9' blade and over track lift cylinders , madea frame in front similar to your cable front and put 2 - 3" X 34" cylinders on it , used front pump and mounted hyd tank ahead of rt side battery box with hyd control valve off that to easy hand reach.
 On those rear axles , 2 styles one with small spline and other with large spline , also earl ones were rifle drilled to oil outboard bearing.  Anothe rplace to be sure you are getting oil or change over to grease is the steering clutch lever bearings as they are oiled off rear housing through a felt wick.  Another felt wick on the pilot bearing on end of crank on the 2-71.
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 11:17pm
This is were we got it from
 from
We have  another hd5b for spars and my son is woking on a hd5a at the monent
This page was generated in 1.105 seconds.
