HD5 |
bill(IL)
Topic: HD5Posted: 22 Jan 2011 at 9:27am |
MY HD5 clutch brake lining is bad. I am told it is discontinued. DOES anyone have a source for it or know the thichness of the lining. It is part of a rockford system. AC #074751 Rockford #CL-8772-38 Thanks Bill
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 22 Jan 2011 at 9:43am |
Check with some heavy truck shops as the clutch brake is similar to those used of class 8 road tractors.May have to shim the plate to get clearance right for it to work.
Remember also not to idle machine with clutch disengaged for long periods as it wears on the brass bushing in output shaft. Put trany in neutral and engage clutch.
