HD5
bill(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill(IL) Quote  Post ReplyReply Direct Link To This Post Topic: HD5
    Posted: 22 Jan 2011 at 9:27am
MY HD5 clutch brake lining is bad. I am told it is discontinued. DOES anyone have a source for it or know the thichness of the lining. It is part of a rockford system. AC #074751 Rockford #CL-8772-38 Thanks Bill
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:43am
Check with some heavy truck shops as the clutch brake is similar to those used of class 8 road tractors.May have to shim the plate to get clearance right for it to work.
 Remember also not to idle machine with clutch disengaged for long periods as it wears on the brass bushing in output shaft. Put trany in neutral and engage clutch.
This page was generated in 0.449 seconds.
