hd-5
jturano11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Topic: hd-5
    Posted: 01 Aug 2010 at 9:07am
I developed a leak at my drive sprocket, it's comming from my final drive. can anyone help me with new seals? also looking for new seals and packing for all my cylinders on my hd-5 loader.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 8:00pm
Loader seals are a V ring packing and can be found at hyd shops or I believe McMaster -Carr also carries some of that.
 Inside or outside on rear sprocket as there are seals on both sides. To change those seals you need to drop the track frame from machine. No way to get the sprocket off unless you do .. If it is a 5G I have found another way but requires cutting and welding of truck frame.
This page was generated in 0.191 seconds.
