hd5 |
jturano11
Joined: 26 Mar 2010 Location: Pennsylvania Points: 34 |
Topic: hd5Posted: 28 Dec 2015 at 1:55pm |
I hear I can replace track adjusters on my hd5 with hyd ones,anyone know where to order them or anything about it?
Thanx |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 29 Dec 2015 at 9:33am |
jturano11
Posted: 30 Dec 2015 at 12:24am |
Awsome,can't thank you enough.while I go the tracks apart I'll have to fix a final drive leak.any ideas of where to buy the seals?
jturano11
Posted: 30 Dec 2015 at 12:29am |
I can tell just by the looks of things it's going to be a not so easy job I'll have to post something for some advice I never replaced these seals before I keep losing oil from left side.
CAL(KS)
Posted: 30 Dec 2015 at 8:31am |
if anyone has the parts new http://www.minnpar.com will. otherwise you may have to get good used. can also view parts books on their site
gemdozer
Posted: 30 Dec 2015 at 11:17am |
I have some new ring seals and boots ass for outboard bearing and should have some boot ass spring for the rear sprocket
gemdozer
Posted: 30 Dec 2015 at 1:57pm |
Before removed the track for changing the seals make sure the big nut on sprocket shaft is't loose
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42279 |
Posted: 30 Dec 2015 at 3:50pm |
to change the seals you will need to drop truck frame from machine as well as disassemble outboard bearing on the truck frame that supports the axle shaft .
Some work is involved in the full process - check archived posts in this section for info .
