HD5 throwout bearing
serioussam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Topic: HD5 throwout bearing
    Posted: 31 Oct 2015 at 9:01pm
I want to put a grease line to the throwout bearing ,can I pull the trunnion pins to move
The yoke so I can put the line on or is it a little more complicated than that thanks
Dozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 6:39am
Look thru the access panel on the clutch housing. Depending on what clutch you have there should be a greese fitting or the remnants of the external lubrication hose. The throughout bearing should be a sealed bearing but the clutch yoke does require lubrication. You should be able to remove the fitting on the yoke and install the lubrication hose. The fitting should be 1/8 NPT. 1/8 hydraulic hose may be to rigid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 9:31am
I was able to get the line off by removing the pin on the steering arm and I could move the yoke to the side. In the parts book it shows it is a 1/4" NPT .How many shots of grease should I give each bearing daily/ weekly .thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 10:38am
If my memory is correct the fittings on the master clutch yoke are 1/8NPT The fittings on the steering clutch are 1/4NPT. I assumed you were inquiring about the master clutch. If you can see greese coming out of the bearing you have greased enough. Unless you use your HD5 over 1000 hours anually, once a year is enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 11:33am
No sorry for not clarifying. I was talking about the steering clutch bearings, so once a year is still enough grease for steering bearings. Thanks
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 3:16pm
A hose for a grease gun works great for this use .
remember to grease the sleeve on the master clutch also - as it turns on shaft it needs lube and also when tractor is at idle - put transmission in neutral and engage clutch so the main shaft is not riding on the brass bushing in this sleeve .
