HD5 Throttle Band
Sun-Nobi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sun-Nobi Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Throttle Band
    Posted: 12 Jul 2024 at 10:13pm
Finally found a starter for the HD5 and fired it up. Throttle returns to idle, small band brake inside throttle assy is rusted and broken. Is there a source for the small band brake or is there something close that can be cobbled to replace that band?
And is there a proper term for that band, cuz every search turns up steering band brakes, ha ha .
Thanks
PS, learned to check the air cutoff butterfly for proper adjustment before starting a 271 for first time. Rack was stuck, slowly built to a runaway as air cleared from system. Shutoff wouldnt work and enough air got past air shutoff so it was necessary to block intake at air cleaner. Not a big deal but would have been an easy check on the butterfly.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 12:50am
2 units were used - early had a kind of round plate mounted on throttle lever , later had a wider casting with a adjusting bolt .
 Might have a old style out back
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sun-Nobi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 5:56pm
Mine is the drum connected to lever with a small band brake and an adjusting bolt. Hoping to find the band with brake material on it. If not available, may be able to make a new band and glue leather on instead of brake material. Leather should last a while.
Thanks for getting back to me.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 12:33am
General Gear in Boise, Idaho has some crawlers that they part out, they may have just what you need.
