HD5 steering clutch
Shaneallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shaneallis Quote  Post ReplyReply Direct Link To This Post Topic: HD5 steering clutch
    Posted: 08 Feb 2020 at 1:57pm
The right steering clutch is locked up on our old Allis HD5. We took all the bolts out of the drum and the instructions we have just say to hook on to the break band and pull it out. We can't get this thing to budge, are we missing a step? Any advice would be appreciated.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 7:36pm
Make sure you have removed 8 bolts from outside flange to the pinion and 10 bolts from inside hub drive and you need approximatif 1/8 inch loosed for pulling the drum assembly sometime you need to knock with a hamer om side drum to make loosed,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shaneallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2020 at 4:14pm
Finally got it out, but the teeth are not in good shape. We're probably going to need a new drum if anyone has one or knows where to find one it would be appreciated.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2020 at 6:46pm
Gem Dozer you have anything left.  Or General Gear in Idaho. A lot of aftermarket parts for steering clutches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2020 at 7:28am
Yes am still have a new one
