HD5 starter info
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Topic: HD5 starter info
    Posted: 18 Jan 2022 at 8:59pm
Anybody know the tooth count on a starter for an HD5 with a Detroit 2-71? I read somewhere that it should be 11 but mine has more than that. Not sure of the exact count but it’s not the original starter. This one has an electric solenoid for the bendix instead of manual operation. Any help or advice would be appreciated.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 10:33am
40MT 42MT 50MT 11T STARTER DRIVE FITS DETROIT DIESEL
Seems the teeth have to match the ring - and 11 tooth is the norm .
I have the 40 MT starter on my HD5G and have replaced the original unit on 3 other machines  with the same starter series as parts for old starters are hard to come by , and by using solonoid rather than the rod to switch on old starters it makes a simple upgrade .
  Found a rebuilder here who gave me full credit for old starter so cost was around $100 for the update .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 10:41am
Thanks Coke. So you had to convert the starter over to 11 teeth?
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 2:06pm
Update: I’M AN IDIOT or I can’t count. I marked a tooth and it’s 11 teeth. My mistake. Sorry guys.
