HD5 serial number location
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Topic: HD5 serial number location
    Posted: 14 Jul 2018 at 6:29pm
Where is the S/N stamped on my HD5 Dozer? I looked on top of the back housing by the steering clutch cover but can’t see it.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2018 at 10:01pm
It is on the back of the housing,cnot the top. You were within inches of it.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2018 at 10:51pm
Left rear case on back side of casting about 1" down from top , if it is a HD5G with counterweight it may be covered over .
 Also on plate on dash on right side of throttle housing but just above the brake pedal
If a B then you should be able to see it on the back side - look above the draw bar housing straight up
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 6:25am
On my HD5B it is on the right side about an inch down from the top. Straight back from where the linkage goes down into the housing next to the steering clutch cover.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 6:38am
Yes the serie number should be on right side but if you have a winch or ripper the serie number should be covert.
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 1:18pm
Thanks guys! Hard to see with the winch in the way, HD5B 5764. Anyone know what year that makes it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 6:38pm
Per CH Wendell's book, 1949
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 8:25am
Thanks Dave!
This page was generated in 0.406 seconds.
