HD5 radiator
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: HD5 radiator
    Posted: 07 Sep 2016 at 10:56am
Anybody on the forum looking for a HD5 rad? I work for a company that makes heavy duty cooling systems and one of the Customer Service guys (he knows I "collect" AC stuff)told me we had an inquiry. Kind of on the small end for us but would be fun to build. It looks to be about the same size as my D17 rad.
Anyway I thought I would check in here and see if the inquiry came from someone on the forum.
cheers,
Creek
Have spacesuit, will travel
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 4:15pm
I do not need one but I would like to know what one would cost if i did.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 4:54pm
Size is around the same as a 46/47 Chev as far as height and width but 3 times as heavy and thickness - I had a brand new chev one and used it on HD5B I had but created overheating problem when worked -
 I found a good used one from Thill Tractor in Eau Clare WI - but that was years back
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 11:47am
My HD5 has a weak radiator needed repair every other year. Repair shop said it was done,I begged for one more fix as no money for a recore then so he fixed once more.Leaking a year later and took it back for a rebuild as I had more money,now says I can fix that . Been good for several years now,but run very few hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 1:19pm
Looks like it was not a forum member, our CS dept said the owner was 93 years old and wanted to fix the rad good so he wouldn't have to bother with it again.
We don't normally do small rads like this, but we will give him a price. Our construction is very heavy duty and therefore pretty pricey, we normally start at 1000 hp engines, unless it is a severe application like underground mining or remote genset.
cheers,
Creek
Springer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Springer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 9:55pm
I’m Eb Springer and yes I am looking for a Hd5b radiator or a new one.
      The one I have is in working condition but leaks a lot and I’m in a bind to find a new one or one in good condition.
     Can y’all help? Thanks anything will be helpful
Post Options Post Options   Thanks (0) Thanks(0)   Quote Springer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 9:58pm
My Hd5b is a crawler dozer and I hope y’all can point me in the rite direction
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 10:27pm
Are you 93 Eb?
Allis Express participant
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 4:24am
He would be 96 now as this was an old post!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 10:35am
Ha, didn't notice!
