HD5 Problem
Mktlne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mktlne Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Problem
    Posted: 04 Jan 2013 at 9:50pm
Hi! New to forum just purchased a HD5B and I have a problem with left track not wanting to work, looking in the steering clutch resevoir 1/4 full of liquid is this norm for 1946 or is it supposed to be dry. I am assuming the clutch is froze up. Any help would be appreciated.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2013 at 11:00pm
The clutch compartment should be dry and free of rust on the clutches. I have one to redo and has both clutches stuck.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2013 at 5:00am
The HD5 stering cluch are dry just remove the plug under housing for draining
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mktlne Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2013 at 6:59am
Thanks for the reply
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2013 at 1:07pm
On bottom of tractor is a 3/4" pipe plug . This is to be left open as a case drain unless working in wet location. Inside of case also seems to attract mice and collect things which will block drain hole - creating problems.
Also on underside of machine is a bolt which is used to support the brake band to keep it from dragging on brake-clutch drum.
 If the clutch will not release - removal and clean up of clutch is the option .
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2013 at 11:19am
On page 8 of this forum there is a posting "What is the tensile strength of a mouse nest" This tells about the steering clutch problem on my machine. The posting date was 19 August,2012
This page was generated in 1.767 seconds.
