HD5 pins bushings etc carco winch |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34643 |
Topic: HD5 pins bushings etc carco winchPosted: 11 Jun 2013 at 12:44pm |
I have a little 7+ton HD5 dozer with winch
Tracks are not the greatest... Heres a pic.
Must be the new style see thru bushings? LOL
![]() Think a simple pin and bushing turning would do it? LOL
Does anyone have:
1. dimensions for the links?
2. New pins and bushings .. if links are acceptable yet.
3. or some good rails? and possibly sprockets too?
Here is pic of worse side.
![]() Think this sprocket is cherry?
cut off/weld on or find nos ine piece sprockets?
Also Does anyone have a bit of info on a Carco winch E-24?
One lever has forward nuetral and reverse , does the other handle have a brake? My handle is not attached at the moment.
gemdozer
Posted: 11 Jun 2013 at 2:47pm |
The HD5 new links tightness are 3.687" and what I can see you need pine,boushing and sprocket and for the whinch you should have a lever for the brake and second for reverse and forward
JC-WI
Posted: 11 Jun 2013 at 3:03pm |
Gemdozer, I think I need 66 pins and bushings, 33 of them for sure.
Are whole or weld on sprockets available yet?
Maybe have to set up on a jig and weld up and grind down the teeth and then heat treat?
Tried http://www.crawlerheaven.com/tracklinks_chart.htm but this link doesn't work for me.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 11 Jun 2013 at 4:15pm |
There are parts on eBay located in Maryland. Weld on sprocket rings are available. There are 2 different sprocket splines.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42279 |
Posted: 11 Jun 2013 at 4:37pm |
ac_sd
Posted: 12 Jun 2013 at 4:47pm |
I've got 2 sets of good tracks and sprocket rims for HD-5B... Located in San Diego (long way from Wisconsin).....
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 12 Jun 2013 at 5:19pm |
the winch levers: one is for forward/reverse, the other lever is for engage/freewheel. there is not brake on these winches. cables usually freeze up and do not work properly. I have a used set of tracks, the pins and bushings need to be turned, inside wear more than outside wear. rails are decent, slightly rounded on the outside edges but still useable. I think berco still has the weld on sprockets but not sure. pm me if interested. located in pa, a good ride from Wisconsin.
